Front bushings stock, 1LE, or poly
My car is a 1995 Camaro Z28 M6 and i am currently building a 396 for it. Since i have my k-member down, because the engine is out i decided to replace the front end suspension components. The car will be mostly street driven.
My question is about the upper and lower control arms. I am wondering what bushings to go with and what others have experienced. I was thinking of going with the polygraphite bushing from P-S-T, but from searching on the internet i am questioning if poly are the right way to go. I have read alot about the rear LCA binding if the have poly in both ends is that the same case with the front end control arms?
If i am going to have problems with binding i would like to go with the 1LE bushing because they are a stiffer bushing than stock? The problem with the 1LE bushing is trying to find the part# for the bushings. If someone has these please post them.
Thank you very much for your help.
Aaron
Aaron
