Carbureted LSX forum - Oil pressure sending unit adapter
1badeagle
05-29-2012, 10:43 PM
Hey everyone, Im in the middle of installing my new gauge cluster in my car and need a little help. The sender that came with my new gauges is a 1/8" NPT. I need some sort of adapter to go from the stock size sender to the new sender if there is such a thing. Im trying to put it at the back of the valley cover like stock. If you can help, please let me know.
Thanks,
Dustin
89gmcs15
05-29-2012, 10:54 PM
i drilled a hole in the sensor housing after breaking the plastic stuff off then tapped it with a 1/8 npt tap.
1badeagle
05-29-2012, 10:59 PM
Interesting, Do they not make a adapter?
I can thread the stock sender into a 1/2" MIT fitting, but its not tight. It still wiggles some. Does anyone know what this is?
89gmcs15
05-29-2012, 11:03 PM
i think its like a m12 fitting. honestly this was a 10 minute job and looks good. i could get a pic for ya tomorow if ya want.
89gmcs15
05-29-2012, 11:04 PM
dont quote me on the size tho. i could be wrong ha
Graybeards64
I used part number 1822268 LS Series Oil Pressure Sender Adapter from Speedway motor.
1badeagle
05-29-2012, 11:26 PM
I would appreciate that sir.
dr.dub
05-30-2012, 01:55 AM
http://www.speedwaymotors.com/search-Ls-adaptor.html
sic7camaro
05-30-2012, 03:15 AM
Autometer 2268 for oil.
1badeagle
05-30-2012, 03:30 AM
I went ahead and order this one.
1badeagle
05-30-2012, 03:31 AM
Thank you everyone!!
ZONES89RS
05-30-2012, 06:05 AM
I am pretty damn sure I ended up with a fitting that came from a kit for adapting water temp on all mine that fit the oil sender every time. Weird.
89sierra
05-30-2012, 08:47 AM
like mentioned i used the autometer one that went from a metric thread to the 1/8npt
3pedals
05-30-2012, 06:31 PM
I did it the zero $$ way as well, knocked off the plastic of the oem sender, then tapped it 1/8 NPT
ZONES89RS
05-30-2012, 08:30 PM
One I did was found a fitting that fit the motor but the oil sender piece slid in, JB weld and BAM, perfect. Lol
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
