Best pistons for forced induction?
Old 05-30-2012, 01:36 AM
chevyforlife's Avatar
Default Best pistons for forced induction?
I recently melted another piston in my turbo Camaro I'm not to sure what I have going on but this keeps happening I'm just wonderin what you guys think is the best piston set for forced induction all info would be really appriciated thanks
Old 05-30-2012, 02:22 AM
Exidous's Avatar
Wiseco or Diamond with the 2618 casting.
http://www.texas-speed.com/p-1082-di...-6098-rod.aspx
or
http://www.texas-speed.com/p-1283-wi...iston-set.aspx
There are various dish versions to get your comp ratio right where you want it.
Old 05-30-2012, 02:25 AM
I was thinkin diamond thanks for your input
Old 05-30-2012, 02:40 AM
Can someone point me in the right direction as to who to order a set though?
Old 05-30-2012, 02:45 PM
IRONFIST's Avatar
What pistons were you using before?
Old 05-30-2012, 02:54 PM
BigRich954RR's Avatar
need way more info most likely there some thing wrong to melt a piston.
but the best pistons are one that are hard coated and are made to be hard coated
Call steve morris about hard coated pistons their are a few other places that do them but im never worked with them
Old 05-30-2012, 03:05 PM
96capricemgr's Avatar
Realistically if you have melted several pistons and it has not scattered and hurt the rest of the motor, then whatever you have been using is probably decent, sounds like you know there is a cause to this focus more effort on finding that.
If you put a bulletproof piston in that is somehow able to stand up to what is going on then something else will just fail, the bearings will be hammered out, melt a valve etc.
Old 05-30-2012, 06:54 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Like said before, what was your setup that you melted a piston? Are you talking about a cracked ringland, or actually metling a piston. If you melted a piston, then it's getting extremely hot, which I would focus on cooling the chamber and piston no matter what piston you decide to run.
Old 05-30-2012, 08:20 PM
I had two sets of mayle pistons and my set up is a Tc-78 turbo 4" intercooler and dual meth nozzles I'm pretty sure my problem is how I have my feed line supplys the rails so I'm gonna change that and get bigger injectors so I can eliminate it being a fuel problem cause it's always been on the driver side that melts
Old 05-30-2012, 08:41 PM
I have 60lb seimens right now duel 255s in tank and switched to return style system
Old 05-30-2012, 08:46 PM
COPO9560's Avatar
or
Not to be an *** but 2618 alloy is used for forged, not cast pistons. This is the best alloy for a production style piston for FI.
Old 05-31-2012, 04:21 PM
Exidous's Avatar
Fair enough
Old 06-01-2012, 05:45 AM
just get them hard coated
Quick Reply: Best pistons for forced induction?
