H/C LS1.....how much timing?
My buddy has a 99 TA track only car. It's a stock bottom end, prc 2.5 5.3 heads with cam and ls6 intake. The car has a msd 6010 box on it. Right now all the curves have 36 degrees of timing which I think is too much. I think the curve pills that come with the box are geared more toward Carb cars.
I can set it to whatever I wish with the msd box, how much should I try?
my car has its max timing at wot set at 25 or 26,anything more was useless.Really depends on the combustion chamber efficiency.With the 243 heads or aftermarket heads and high compression,24 would be good.36 is really high,and unless you log the KR,your shooting in the dark
