Stereo & Electronics - dynamat a 2000 camaro
View Full Version : dynamat a 2000 camaro
surfsideracing808
05-31-2012, 01:35 PM
http://www.amazon.com/gp/product/B00020CB2S/ref=olp_product_details?ie=UTF8&me=&seller=
Would this be enough to do the entire car. Or at leased from the gas peddle to the back seat?
jmilz28
05-31-2012, 01:51 PM
From the gas *pedal to the tail lights will require a solid 100 sq ft. I would avoid Dynamat, it's the most expensive but not the best. Best is Second Skin Audio. I used eDead by elemental designs. You don't NEED to cover 100%, but you'll have to compensate for that with care and multiple materials. Start here: http://www.diymobileaudio.com/forum/member-reviews-product-comparisons/128154-sound-deadener-showdown.html
WhiteBird00
06-01-2012, 08:35 AM
From the gas *pedal to the tail lights will require *at least a solid 100 sq ft.Fixed it for you. :jest:
bayer-z28
06-02-2012, 02:25 PM
^ I used ~80 sq/ft for mine and I pretty much went OCD on the interior. Pedal to tail lights. and all the nooks and crannies in the back end.
Just haven't done the doors yet. Was gonna replace the speakers first.
So 100sq/ft will do fine. If you need more, a local stereo place should have a couple extra cubes for you to finish.
