March vs. ASP Pulley
Old 03-30-2004, 11:00 AM
RedDemon2's Avatar
Default March vs. ASP Pulley
What's the best pulley? I'm debating between the March and ASP Pulley. Which is the better package? Anybody know the part # on these Pulley's because I want to make sure I order the correct package. In Thunderracing.com it shows me different packages. Which one does everyone go with?
Thanks on any info!!!!!
Old 03-30-2004, 11:44 AM
horist's Avatar
TTT I already have an ASP but am curious about these March pulleys...
Old 03-30-2004, 11:56 AM
BADSZ28's Avatar
I too am interested in the March. I know that it is a fluid dampened pulley, but I would like to know what material it is made of as well as the percent underdriven.
Old 04-29-2004, 08:07 AM
SidewayzOZ's Avatar
Lets bring this back TTT...Id like to know as well.
Old 04-29-2004, 04:41 PM
D Rock's Avatar
I know the march pully weighs 11 pounds compared to 10.5 for the stock pully.
The asp is somewere around 6-7.
That should give you your answer right there.
Though i'm still wondering how this SLP pully is performing.
Old 04-29-2004, 05:03 PM
SidewayzOZ's Avatar
When I searched for this I also came across some posts that said this was not the case, that the March weighed in pretty close to the ASP.
Old 04-29-2004, 05:18 PM
Josh's Avatar
From what I remember, the March pulley is heavier than the ASP by several pounds, but is slighty smaller than the ASP. Despite its weight, because it is a fluid dampened pulley, it should be more efficient than the ASP at dissapating power-robbing and potentially harmful crankshaft vibration.
Josh
Old 04-29-2004, 05:51 PM
PREDATOR-Z's Avatar
OK if you compared an equal weight steel pulley to the March, I could understand the worries. March is FLUID dampened and will definitly outperform any solid pulley in that field. It is 25% underdrive.
One of my next mod with H/C for sure.
Old 04-29-2004, 10:00 PM
wrencher
wrencher's Avatar
The place to look for weight savings is not the balancer.
Lets try to do the same job with less mass?
Wonder why the early ones had knock retard issues?
Little to much crank flex going on there?
There is alot to be said for functionality & longevity of the motor verses saving a few pounds of recipitating weight.
Old 04-29-2004, 10:16 PM
SidewayzOZ's Avatar
I think I'll be buying a March pulley, you guys rock
Old 04-30-2004, 08:01 AM
Super Moderator
Reckless's Avatar
I would steer away from the March. It was the pulley used on the 1150hp engine my friend has. To make it short, the timing chain ended up getting bound up due to bad harmonics. Not saying it isn't a good pulley, but it was removed, changed the timing chain, and used an ATI instead. I believe the ATI is prolly the best bet, but ASP is good also for less $$$.
Old 04-30-2004, 08:08 AM
RedDemon2's Avatar
Good Info! I'm ordering the ASP Crank pulley this week.
Old 04-30-2004, 12:18 PM
SidewayzOZ's Avatar
Got a link to the ATI pulley? Looks like were getting alot of mixed opinions here.
Old 04-30-2004, 12:33 PM
Sweet Cheeks
Damage Inc.'s Avatar
The ATI dampener pulley is superior for harmonically balancing high RPM motors, but it's costly. For a typical street car or car not exceeding normal range RPMs I support the ASP pulley and wouldn't(didn't) pay nearly $500 on a unnecessary pulley.
Old 04-30-2004, 12:35 PM
Stew w/92&00's Avatar
ASP is pretty proven....
Old 04-30-2004, 12:39 PM
2001CamaroGuy's Avatar
50K miles with the old ASP pulley (still in brand new shape). When I built my new motor I baught the SFI version just cause so I would start 100% brand new on parts.
ASP works for me
Old 04-30-2004, 01:20 PM
Larry's Avatar
The ASP pulley weighs less because the center hub is aluminum. That has nothing to do with dampening and harmonics reductions. The outer ring which is mounted on molded rubber between it and the hub is steel for the necessary weight required to eliminate harmonics.
The newer ASP pulleys are also SFI approved.
Old 04-30-2004, 02:10 PM
SidewayzOZ's Avatar
Alrighty...maybe I'll be buying an ASP instead then. I feel like a ragdoll What exactly does the SFI approved mean? My only concern with the ASP is I had read about past problems with false KR being reported due to the pulley. Im guessing this has been solved since so many users are using this pulley without problems.
Old 04-30-2004, 02:57 PM
Larry's Avatar
The false Knock problems were reported from an all aluminum pulley that is made by another manufacturer.
Old 04-30-2004, 03:01 PM
SidewayzOZ's Avatar
You are correct...apparently there was a bad batch of Whisper underdrive pullies, and that was quite a long time ago (99). Thanks for setting me straight on that.
