0235SS
05-31-2012, 04:54 PM
So I always wondered why the heck GM didn't do better on giving us (98-02 Camaro owners) brighter fog lights...
I hate the fact that instead of using real projector fogs they made some crappy ass fogs with a shield inside to give them the projector look. I ended up opening the fog lights by removing the lens with a small flat head screw driver (ones to open up watches with) be very careful because the lens can easily crack (use a heat gun if you have one in handy), then remove all the silicon with a razor blade. I would recomend since the lense is out clean it with some meguiars ultimate compound, then there's a shield in the middle inside the fog light, all you have to do is push it in from the sides and it should pop out,*also what i would recommend would be to go to any auto zone or even on Amazon.com and buy one of those aerosol chrome paint cans and spray the inside* no matter what it will be brighter since you will be removing the shield that blocks off light output. after you do the last steps just simply apply clear silicon or use a silicon glue gun... all done, try it out and post up your results and feedback on here. '''
http://i1225.photobucket.com/albums/ee386/SSLE340/MAKING%20LS1%20Camaro%20FOGS%20Brighter/20120531_122112.jpg
http://i1225.photobucket.com/albums/ee386/SSLE340/MAKING%20LS1%20Camaro%20FOGS%20Brighter/20120531_124251.jpg
http://i1225.photobucket.com/albums/ee386/SSLE340/MAKING%20LS1%20Camaro%20FOGS%20Brighter/20120531_124302.jpg
http://i1225.photobucket.com/albums/ee386/SSLE340/MAKING%20LS1%20Camaro%20FOGS%20Brighter/20120531_120755.jpg
http://i1225.photobucket.com/albums/ee386/SSLE340/MAKING%20LS1%20Camaro%20FOGS%20Brighter/20120531_120812.jpg
http://i1225.photobucket.com/albums/ee386/SSLE340/MAKING%20LS1%20Camaro%20FOGS%20Brighter/20120531_120918.jpg
http://i1225.photobucket.com/albums/ee386/SSLE340/MAKING%20LS1%20Camaro%20FOGS%20Brighter/20120531_120903.jpg
