Does anyone know how to get ahold of sscamaro1384
Category: Accessories
Price: $9
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): FL
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
did you set the tps to .57 volts? did you do a tps relearn? does the throttle blade have a larger than stock hole in it (if so, swap the throttle blade for a stock one)? i think it may be installer error.
hey im right here. sorry for the late response i dont have a home computer at the moment. I m not 100% sure on the problem u are having but i think i do have another stock throttle body if u want that. i think u told me the one u had gotten from me was slightly moded? i thought it was stock but if u are for sure there is a problem with the tb i sold u, then id be glad to see how we can clear up this transaction
Hate threads like this that make people look bad...
You gotta do some searching before you accuse someone of shadyness... it could be any number of things causing the car to not idle right. Details would help, such as your cars mods, details on the TB (stock? aftermarket? ported?). Depending on your situation if you have engine work done and/or if the TB is worked or aftermarket there are things you need to do that are a given in order to achieve proper idle. (set tps, drill IAC hole, ect..) Many things it could possibly be.
Well let me first say I'm not trying to make him look bad... I am trying to get ahold of him so we could talk and see what we can accomplished, yes I did some real diag... I did do a searc as well as two other people helping me with the car. I didn't do everything that was told to me on here. And to sscaramo yes I would rather have a stock one reason being I just needed a core to ship to potz speed and performance. Sort for any and all confusion. Once again sscamaro was a great seller I was unaware his had no home computer I would buy from again, like mention earlier I was trying to get in touch with him. Just contact me with any info so we can figure out what to do about getting me a stock and I can send you back this one.
Thanks
Thanks
