Drag Racing Tech - Meziere 119 What's Needed
RENE'S RAGE
06-02-2012, 12:05 PM
What all is needed to install the pump?
Can you use the stock hoses?
Do you need a t-stat for track only car?
Firehawk441
06-02-2012, 02:05 PM
1) Pump is a direct bolt on with correct size hose nipples.
2) Stock hoses work fine with a stock radiator. No provisions for using heater hoses with this pump.
3) I had no cooling issues in a race only application with the optional 40 GPM 119 pump and no thermostat.
RENE'S RAGE
06-02-2012, 04:21 PM
Thank you Sir!
RENE'S RAGE
06-12-2012, 04:30 PM
A dealer told me that the 319 pump would bolt right up.
But the 119, you will need different hoses, an inlet nipple and a inline t-stat housing.
Firehawk441
06-12-2012, 07:47 PM
Stock upper hose without P/S cooler is what I used. Fit perfect.
For the lower hose I used a stock C-4 Corvette hose. (I forgot about that. Sorry.) I should still have that hose. I'll check and let you know. That fit perfect also. I may still have the nipples laying around also.
As far as a thermostat, I didn't need one.
The correct inlet and outlet nipples I mentioned before.
If I find the lower hose, I'll send it to you or give you the exact year and application for it. Sorry for the misinformation on that hose.
Firehawk441
06-12-2012, 08:06 PM
I found the lower hose I used. Here's a picture of it.
http://i557.photobucket.com/albums/ss17/firehawk441/securedownload1144.jpg
JL ws-6
06-12-2012, 08:24 PM
The lower hose I used was a volvo hose if I remember right. I took 3 pieces, and a couple pieces of pipe, mocked it up and went to autozone, and went thru the hose rack until I found something that was as close as possible.
RENE'S RAGE
06-13-2012, 04:28 PM
No problem on the info. Hell, I can barely yesterday!
No need to send hose, it would probably cost more to ship it than buying a new one. Do you have a part # for it.
If you got the nipples, I'd like to see a pic of them.
Thanks
Firehawk441
06-13-2012, 07:04 PM
I'll have the exact application of the hose for you tomorrow.
I can't find my old nipples but this link will show you all the different sizes Meziere makes.
http://www.summitracing.com/search/Brand/Meziere-Enterprises/Product-Line/Meziere-NPT-to-Smooth-Hose-Adapters/?autoview=SKU
You'll have to measure the I.D. of the hose you're using and order the nipple accordingly.
RENE'S RAGE
06-13-2012, 07:28 PM
Thank you for your time.
Firehawk441
06-15-2012, 05:35 AM
No problem.
1988-1989 Corvette is the application for the lower hose I used.
RENE'S RAGE
06-15-2012, 04:06 PM
Damn, to bad it's not a '99 Corvette, I could have stole the hose off the old ladys car. LOL.
Thanks again.
The Guy in MY 99TA
06-17-2012, 11:36 PM
anybody got pics of said setup? I can't figure out if I wanna run the 319 pump or the 119 pump... I wont be doing much street driving especially in the summer but I hate to spend another 200 bucks on a pump that I dont have to have
