Pontiac GTO 2004-2006 - 04 Severe Steering Shimmy
View Full Version : 04 Severe Steering Shimmy
acevhartz1
06-02-2012, 04:10 PM
I've had a slight shimmy for a couple years when I brake and a slight "delay" when I turned the wheel. While I was driving down the highway I turned my wheel to make a turn and the wheels didn't start turning until I had turned the steering wheel over 90 degrees. It does this both to the left and right. I jacked up the car and had a friend turn the wheel and I hear what sounds like the it was squirting fluid inside the rack and pinion. Is there a bleeder port on it? I cant see one. Or is the assy. just done? Any input would be greatly appreciated.
Robofuzz
06-02-2012, 07:26 PM
Check your front radius rod bushings and tie rods.
O-FiveCC
06-06-2012, 06:38 PM
Strut top bushings, radius rod bushings, and tie rods. Check, and better yet, replace them all.
