1996 Formula LT1 to LSx conversion
Old 06-02-2012, 10:58 PM
94LTZ's Avatar
Default 1996 Formula LT1 to LSx conversion
After having some issues the car is finally coming together so i'll post up some details.
Bought the car just over a year ago and have done a ton of work to it so here it goes.
First build-
Car was sold to me as a roller so i put my old 350 into it, ram power grip clutch, 390's, ported heads, custom cam, long tube headers, twin 52mm, elctric pump etc. Was a fun car but had a bad vibration which was later figured out to be a messed up crank from when i had it in my camaro putting spray to it so i went LSx like ive wanted to do for years.
This build-
Picked up a LS k member, steering rack and linkage from member on here and so it started.
Engine-
Stock 5.7 block
Stock crank
Ross racing pistons
Forged Eagle H-beams
Custom Cam
Comp adjustable timing set
Milled 243 heads
.650 patriot springs
Ported LS6 oil pump
American Racing long tubes
Stock intake (looking for a LS6)
Transmission-
Converted my LT1 t-56 to a LS1 t-56
LS7 clutch kit
Misc-
LT1 WS6 hood
FIPK
OE Wheels C6 Z06's
I used a diagram from Flame and looked over the thread Merv did to convert the wiring, pretty simple actually.
Old 06-03-2012, 07:11 PM
94LTZ's Avatar
Well fixed my throttle problem, i am running a Non T/C cable new from gm for a 02 Z28 but i about a inch to long and had a ton of slack, i took my extra gas pedal and bent it about an inch and it works perfect.
Now i just need to clean up the wiring and get the cooling system bled and hope to have her at the exhaust shop
Old 06-03-2012, 07:24 PM
the_merv's Avatar
Good stuff. The wiring really is pretty simple.
Old 06-03-2012, 07:28 PM
94LTZ's Avatar
Yeah its not bad at first seems like a pain in the ***. I dont care for it but found my self doing a ton of wiring on my latest builds.
Thanks for the help with this one man, you helped alot.
Old 06-03-2012, 08:43 PM
the_merv's Avatar
No prob..
Old 06-04-2012, 09:24 PM
94LTZ's Avatar
Started installing the SJM ABS delete and line lock kit today, i hate the lines they send to cut and flare so i replaced them with stainless braided line on both my cars, i think its a cleaner look. Luckily i i have a buddy that works at the local tube and hoses so it only cost 1/4 of a body part instead of 3/4.
Hope to have it ready to take it's first drive this weekend but not sure it that will happen with me being on call.
Old 06-04-2012, 09:39 PM
LS102ws6's Avatar
nice swap glad to see it worked out.
Old 06-04-2012, 10:02 PM
94LTZ's Avatar
Here is a video, sorry the qaulity sucks but you get the point.
http://www.youtube.com/watch?v=cOcud...ature=youtu.be
Old 06-05-2012, 08:34 AM
Rick Speed's Avatar
Yes the throttle body's are different. So if you use an older one with the newer cable it doesn't fit. Just FYI
Old 06-05-2012, 10:07 AM
94LTZ's Avatar
Throttle body is from a 2001 z28.
Quick Reply: 1996 Formula LT1 to LSx conversion
