Possible to use oem retainers for PSI 1511ML springs?
Old 06-02-2012, 11:19 PM
LSXFEIN's Avatar
Default Possible to use oem retainers for PSI 1511ML springs?
or should i get aftermarket?
LSXFEIN is offline
Old 06-03-2012, 01:33 AM
LSXFEIN's Avatar
bump........
LSXFEIN is offline
Old 06-03-2012, 03:55 AM
PREDATOR-Z's Avatar
Yes you can, but if you are dropping the coin on some of the best beehives out there, why cheap out? Get matching titanium retainers. They will seat better and control harmonics that could result from less than perfect tolerances while using stock retainers.
PREDATOR-Z is offline
Old 06-03-2012, 05:17 AM
RQSGTO's Avatar
I have PSI 1511ML springs and i'm using the stock retainers that came with my LS6 heads. I cheaped out to use the money towards my current build, plus the light weight valves help.
RQSGTO is offline
Old 06-03-2012, 10:10 AM
LSXFEIN's Avatar
Default ok
right on ima order some! what do you recomnened? patriot gold?
LSXFEIN is offline
Old 06-03-2012, 10:12 AM
LSXFEIN's Avatar
Default ok
Right on i have some from my 799's but i just wanted to double check!
LSXFEIN is offline
Old 06-03-2012, 11:22 AM
LSX Mechanic
Damian's Avatar
I answered you in your other thread. No need to make another one.
Yes you can use stock retainers. As Predator said, they're the best beehive on the planet and some titanium hardware would be icing on the cake but if you're on a budget the stock locking/retaining hardware will work fine.
Duplicate thread, done.
Damian is offline
Quick Reply: Possible to use oem retainers for PSI 1511ML springs?
