Cwarta
06-02-2012, 11:38 PM
Well, FINALLY got the cam installed! Car sounds, different than i thought it would, but i like it. Its currently untuned, will be getting tuned tomorrow! All in all the install wasnt to bad, but i do have a decent oil leak somewere, and its going to have to go up on the lift again. Also, i believe i have to short of pushrods...... Valve train is real noisy, im going to have my tuner look at it tomorrow to confirm.
The install:
246/240 .598/.608 113lsa
25%UDP
Trunion upgrades
Comp magnum pushrods
Lunati dual spring kit (Tools steel retainers)
Hinson Poly mounts
SLP oil pump
HD ls2 chain
Drivabality untuned is WAY better than i thought it was going to be, surging at idle, cruises fine, dosnt die at lights etc....
What do you think, camera sucks as you can see
http://www.youtube.com/watch?v=VVoINPkaXdk
The install:
25%UDP
Trunion upgrades
Hinson Poly mounts
SLP oil pump
HD ls2 chain
