Battery relocation engine ground location
Old 06-03-2012, 04:07 PM
Z28Roxy's Avatar
Default Battery relocation engine ground location
Would it be ok to take off the OEM ground and run my 1/0 cable from there (location is the large stud next to the motor mount bracket) to a spot on the body underneath the coolant catch can? I was going to drill a hole, grind paint away, and install with a large (1/2" bolt and nut)?
Old 06-03-2012, 04:43 PM
TimmyZ28's Avatar
If you grind away the paint and assure that you have bare metal to metal contact, it should work. Just make sure you tighten both ends down because a loose ground can cause major headaches.
Old 06-03-2012, 05:19 PM
96LT1355Z28's Avatar
^^What he said
Old 06-03-2012, 08:46 PM
robsquikz28's Avatar
Yup I have been running a engine to frame ground for years with 0 issues. Just make sure its great contact
Quick Reply: Battery relocation engine ground location
