Dynamometer Results & Comparisons - CSP LS1 GTO w/ Ai 219cc CNC'd 241's - 455/397
Advanced Induction
06-03-2012, 07:13 PM
Andrew at CSP (http://www.completestreetperformance.com/index2.shtml) has been doing great work making sure his guys' cars get assembled, adjusted, and calibrated properly so they run to potential. They're offering quite a service when a guy can simply drop off & pick up his car later with another 140rwhp from a reliable setup that drives like stock, and doesn't add weight to the car.
2004 LS1 GTO:
Ai 219cc CNC work (http://www.advancedinduction.com/LSX/AiLSx219ccGMLS1Head.php)
CSP 224/230 114 HR (http://www.completestreetperformance.com/index2.shtml)
Pacesetter Headers
FAST LSXR TB and Intake Manifold
LS7 Clutch
LS2 Injectors and Fuel Rail
Svede Intake and IAT relocate Kit
Think he noticed a SOTP difference when he picked his car up from CSP?:lol:
http://www.advancedinduction.com/Dyno/CSP_bartLS1GTO_Ai219cc241.jpg
The owner also has a thread on LS1GTO: http://www.ls1gto.com/forums/showthread.php?t=441920
Thanks guys!
-Phil
JayplaySS2
06-03-2012, 08:39 PM
Very nice work!
Camaroking1996
06-03-2012, 09:05 PM
Awesome numbers with 241 heads. Great works again AI
98z8uup
06-03-2012, 10:15 PM
Those are some good numbers.
mac62989
06-04-2012, 10:54 AM
Phil, what advantage would the high CR 219s have on this particular setup?
reeperz28
06-04-2012, 08:06 PM
Awesome numbers out of an ls1. AI HEADS work.
Redfire 03
06-04-2012, 08:16 PM
Wow awesome work from AI as usual.
Advanced Induction
06-05-2012, 11:02 AM
Glad you guys like it. CSP deserves credit for putting it together properly - we go to great lengths to ensure our work is extremely consistent, so the potential from set to set is identical. It takes a good condition engine & drive train, and a competent builder to get everything together in as ideal a fashion as is possible. The old 241's can still be made to work pretty well when everything else is as it should be.
This setup should be at ~10.75:1 as it is. The HCR option would have ~11.5:1 w/ the same p2v, and likely pick up a bit. It is primarily useful for maintaining 10.7-11.2:1 while gaining room to run larger cams w/o having to cut reliefs.
Thank guys!
-phil
ScreaminRedZ
06-05-2012, 06:53 PM
God damn, I bet that car is gonna surprise a few people at the local stoplights!
