MT ET Streets
Old 06-03-2012, 07:48 PM
axe1993's Avatar
Default MT ET Streets
Has anyone ran these. My 01 z28 is bone stock. I was wondering about what tire pressure most guys use. I'm also running auto trans.
Old 06-03-2012, 09:08 PM
z28241's Avatar
According to ur other thread, ur talking @ the track, alot depends on the prep, also suspension, but ur all stock, start w/19-20 lbs., go from there, the colder it is the less psi, the hotter the higher..when you add h.p. and experience, things will come together..
Old 06-04-2012, 07:25 AM
Kev SS's Avatar
My old ws6 I ran 19lbs in mine. I had ls6 intake and headers. Ended up running a 8.06 with front sway bar removed on a cool night.
Old 06-04-2012, 08:34 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Car will most likely bog.
Run as much pressure as you can before inducing wheel spin. Then back off.
Being bone stock, get a decent heat in the tire, you maybe in the mid to upper 20's before needing to back down. Your not making any real power and no converter/gearing to worry bout.
*** Just noticed. Are these real ET streets or ET Street RADIALS??
Old 06-09-2012, 02:01 PM
Ray455's Avatar
^^^ agreed
Right now I run my 255/50/16 ET Street Radials on stock a converter, mild suspension, and bolt ons and I can get the car to deadhook at 28-30psi on the street and at the track.
Good luck
