1986 Elcamino Project-Pending 2006 GTO LS2-6 speed
1986 Elcamino Project-Pending 2006 GTO LS2-6 speed install
Time to start gathering parts for the conversion.
I plan to use a Ford 9 inch with the LE brakes from a GTA, 373 0r 411 with a detroit locker. When I talked to the GM techs at the SEMA show they suggested the GM wiring harness for the install.
I have a FI gas tank from a Impala - should bolt right in.
Any suggestion for engine mounts or wiring would be a great help !!
LS1Tech Sponsor
I dont believe the GM Harness will work for the 2006 LS2 24X setup. Are you going to be keeping the drive by wire or going drive by cable?
By the way, welcome to the 86 El Camino Club! : )
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
Wiring
I talked to the GM Tech at the SEMA Show, they have a performance wiring harness that will work, might have to change the crank sensor. Or I could send the factory harness out for conversion. Looking into oil pans (CTVS) & engine mounts. My elky is lowered!!
LS1Tech Sponsor
Mounts
http://secure.ultracart.com/catalog/.../DD-3550C.html
CTS-V oil pan
http://secure.ultracart.com/catalog/.../KIT-1013.html
Both of the above I used in my 86 Elky. We have a harness too, but would need to know if you are sticking with DBW or going DBC.
Jon
PSI
CTS-V oil pan
Jon
PSI
__________________
Ebay Store
Ebay Store
In a position where the low mount A/C would fit (assuming still needing a slight frame notch) which header would work with those mounts. Long tube headers that is.
Also if truck brackets with power steering pulley clear the power steering box on the gbody frame.
Mounts
CTS-V oil pan
Jon
PSI
CTS-V oil pan
Jon
PSI
LS1Tech Sponsor
CTS-V pan fit with no issues.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
Updates
1. Upgrading to C5 brakes Front & Rear-have parts
2. ATX front spindles- pending order
3. SC&C front chassis brace-ordered
4. TSW 18x9.5, 18x8 wheels & tires- order this mth
5. QP 9inch Ford 373 posi- order rear when wheels come in
6. Dirty dingo Mts- waiting for reply
7. AutocKraft or Moroso LS Oil Pan
8. Headers- Looking into-need more info
9. Frame - Pending removal, Boxing, sand blasting, Epoxy paint
