Big fuel system, Weldon, fuel cell, lines,42lb injectors
Category: Engine - Intake/Fuel
Price: $1000
Location (State): NY
Item Condition: Brand New
LS Engine?: Non-LS Part
weldon pump 1100a, specs-1100 hp Inj/1300 hp Carb
weldon 10 micron filter
jegs 100 micron pre pump filter
aeromotive fuel pump controller
aeromotive a1000 fuel injection regulator with pressure gauge
Deatchwerks 42 lb injectors, balanced and flow tested
approximately 16-18ft of 10an stainless braided line. has around 10 ft of heat shielding and protective covering. 90 degree fitting on one end. Other end not fitted yet
all fittings for a 10an line to pumps and up to 10an to 2 8an y adapter
includes regulator fittings
15 ft of 8an aeroquip hose
many many fittings, 90's , 45's, straights
10 gallon or 5 gallon aluminum fuel cell
Only thing I am missing is the rails
