Cadillac CTS-V - Modify the rear cover on an 8.8
jmargo
06-04-2012, 12:10 AM
Have the partial CS 8.8 kit in the que waiting on the driveshaft from DSS. I need to cut the tab off the back cover of the ford rear but not sure how much needs to come off. Anyone have pics that show the clearance between the subframe and sway bar ?
I have seen the pics from the CS site already.
Thanks
http://i164.photobucket.com/albums/u16/jmargo1/Cover.jpg
shadyLS6
06-04-2012, 02:48 PM
98cobra did it. check his build thread.. i just bought mine from CS and will be sending in a core
jmargo
06-04-2012, 03:07 PM
Just posted in thread.
cts-vls6
06-04-2012, 09:49 PM
y won't just get a 94 r a 95 t-brid rear cover they work fine for me i didn't have to cuts or weld
cts-vls6
06-05-2012, 08:25 AM
here some pic. of the rear cover on the car
jmargo
06-05-2012, 11:21 AM
Perfect ! So that big tab really can stay.
Thanks
MotorMounts
06-07-2012, 12:45 PM
I'm not sure what's going on here, I looked at the pictures but I'm scratching my head on how he got that put together. Maybe the 94-95 T-Bird covers are different, but I don't think everyone reading should assume this situation is going to work on every car. Something is "different" here. If the 94-95 covers prove to be a straight bolt in, that would be cool.
shadyLS6
06-07-2012, 03:17 PM
what front 8.8 diff bushings are you running
cts-vls6
06-07-2012, 04:29 PM
i use a 94 t-brid rear diff. the fornt bushing i got from ford dealer for the t-brid with supercharger and i have to add some washers to make the bushing more tighter,note : if any one is to use the t-brid rear diff u will need to get a 03 mustang cobra pinion flange
jmargo
07-04-2012, 07:26 PM
So to make sure I didn't have any problems during my install window I had the tab shaved off. I also needed to make a couple cuts to the cover to clear the bracket. Just waiting on the driveshaft from DSS and i'll be ready to go.
http://i164.photobucket.com/albums/u16/jmargo1/dif1.jpg
http://i164.photobucket.com/albums/u16/jmargo1/dif3.jpg
http://i164.photobucket.com/albums/u16/jmargo1/dif2.jpg
http://i164.photobucket.com/albums/u16/jmargo1/dif6.jpg
http://i164.photobucket.com/albums/u16/jmargo1/dif4.jpg
MotorMounts
07-05-2012, 09:37 AM
VERY well done, not only does the cover fit now but the craftsmanship was well executed. Nice....Job !!
shadyLS6
07-05-2012, 11:24 AM
+1 looks great..
where did you source that diff breather vent? looks great
jmargo
07-05-2012, 11:33 AM
It starts with a well engineered solution ! :usa:
+1 looks great..
From Max's suggestion this is from Summit. Just need to run a tap down the hole.
part # SUM-E730311
shadyLS6
07-05-2012, 12:52 PM
part # SUM-E730311
thanks for the part number.
