Interior sail panel issue
Old 06-04-2012, 08:28 AM
bhound2's Avatar
Default Interior sail panel issue
My driver's side interior sail panel is loose (pulled away and won't wrap around the door seal. Can anyone show me some pics of an interior sail panel replacement so I can try to determine if I have a broken clip or what else may be wrong? Original owner had an exterior cell phone antenna on the back glass. The cable(s) were run under the carpet, up the sail panel, along the headliner and down the glass at the top center of the hatch. It looked like a professional install but I think they missed a clip or broke one.
Old 06-04-2012, 09:07 AM
bhound2's Avatar
Default Found unattached clip
There is a hard velcro clip about 2 inches in from the door latch on the inside of the sail panel. To fix, I simply had to put a lot of pressure on that spot to get the hooks and loops to engage and hold. Problem solved at $0.
Old 06-04-2012, 09:36 AM
PontiacFan's Avatar
TSB #00-08-110-004
Document ID: 753986
Google it, ...
Quick Reply: Interior sail panel issue
