garage clean out CHEAP needs to go ASAP
Category: Engine - Power Adders
Price: $15
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, Front wheel drive vehicles
Location (State): NJ
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
-853 heads complete TMU $75
-valve covers missing 2 bolts $60
-6.0 truck intake $40
-LS1 383 shortblock,99 ls1 block, has 2500 miles, eagle rods (6.125) &
crank(4"), DIAMOND PISTON 3.905 (-4cc)
has billet main caps and arp main studs. $3000
-LS1 covers, timing, rear, valley. $15 each
-LQ4 cam $20
-Crane full roller rockers set, comes with guide plates, studs and pushrods $250
-Roller master LS2 (works on LS1 also) doulbe roller timing set, less than 1k miles $75
-Roller master LS1 double roller timing set, 2500 miles $70
-Melling high volume, high pressure (10296) 1200 miles $80.
-Fbody engine mounts and stands $30
-Weisco 4.1 bore, 6.125 rod, 3.622(stock) crank flatop pistons $200
-LQ9 (square) coil pack mount on brackets w/ harnesses $100
-LQ4 (round)coil pack mount on brackets w/ harnesses $100
-LS1 coils with brackets and harnesses not mounted $100
-C5/6 stock crank pulley, installed but not run $75
-LS2/3 conrecting rods under 20k miles $100 (2 sets available)
-stock ls1 4l60 torque converter, 20k miles, clean $25
-LS1 rocker arms, stands, bolts. under 60k miles $75
-Fbody A/C bracket $20
-Custom sheet metal polished valve covers $75
-(2) 285/30/19 bridgestones with 80% left
-new in box autometer sport-comp boost gauge (3303) $40
-new in box autometer sport-comp water temp gauge (3337) $40
-New in box HID kit 35w/6k color for C5 and any other car wirth same bulb $80
-Single A-pillar gauge pod for 2 1/8 gauge, used in C5 will work in others $25
-A-pillar 3 gauge pod for 01-07 chevy/gmc full size truck $45
[IMG]http://i68.photobucket.com/albums/i36/cyclerage/2012-06-06_08-17-01
_493.jpg[/IMG]
Where are my parts?
I paid on June 5 by PayPal and I get a message yesterday you have been too busy to ship. What's up with that? Nothing is cheap if you don't get your parts. Is any one else having that problem?
