Popping and farting then smooth
slowly learning HPTuners and everyone has been a great help but need a bit more help. ive been tryin to tune it and its running alright but have some issues. while cruisin around it pops and farts until i get into boost then it runs smooth but its really rich. its a 2bar SD tune with no o2's.
i will try and get a log as soon as im able to.
info on the car:
4.8l
t56
edelbrock vic jr intake with low pro elbow
FAST 90mm tb
60lb injectors
NGK TR8's
2 bar map
t76 turbo 8lbs of boost
no o2's only AEM wideband.
ecu is a stock 2001 4.8l
any help is greatly appreciated and thanx in advance
info on the car:
4.8l
t56
FAST 90mm tb
60lb injectors
NGK TR8's
2 bar map
i believe i started with a stock 4.8l tune and then followed HPTuners videos to convert it to an SD tune. since then i havent really messed with it axcept for turning off some of the check engine lights. i dont have my wideband hooked up to the HPTuners but i can log a little bit of it running and driving up the street.
There's A LOT more not right in his tune....it's currently too much for me to sort out (I'm still learning too)...but there appears to be incorrect TQ control settings, pe adder settings, ect. I'm kinda curious as to why no O2s? The tune does not appear (at least to my eyes) to be set up correctly for OLSD.
Also curious how he's been "tuning" much of anything at all without a w/b logging?
Looking forward to seeing a log file.
Yeah like i said i dunno what was on the ecu. It was supposed to be a stock 4.8l 6spd tune and then i followed whatever steps HPTuners video showed for converting it to SD. Then i just went thbrough and turned off some of the check engine lights. I have a wideband hooked up but just not hooked up to hptuners yet. I gotta look up where the 2 wires go on the HPTuners again so i can hook it up.
I am a newb to tuning and this is why im asking for help.
alright so i got to do a little test pass up the street. hopefully you can view this. realize my VSS signal is a bit off. lol
the car pulls but does not feel like i think it should.
