Redline Fab
06-04-2012, 03:04 PM
For the month of June we are going to offer tuning deals for the F-Body guys and gals. This will cover 98-02 Camaro's/Firebird-T/A's
All tuning is done using HP Tuners Software. Dyno tunes are completed on a DynoJet 248 and will include air fuel read outs. This price is for N/A cars. Forced I/D and Nitrous,and SD tunes are higher priced. This is by appointment only. Please call of pm if you need more info or would like to set an appointment
Street and drivabilty tune:
This will include the following:
Set start up and idle tables
Set changes to injector tables
Tuning out of any needed diag. codes
Delete Torque management
Set and adjust timing tables as needed
Change rpm limiter
Adjust fan on-off temps as needed
recal speedo for gear swap/tire size changes
A4-cars setting and adjustment of any needed trans tables
M6- cars delete skip shift ( cags )
Road test car for drivabilty and check fuel trims
Normal price is 275.00 THIS MONTH ONLY : 200.00
Dyno tunes :
Include all the same as a street/Drivabilty tune
Print out of horsepower and torque curves with air fuel graph
NORMAL PRICE : 400.00 THIS MONTH ONLY : 300.00
And as an added bonus to our tuned customers, any retunes that need to be done for added on or combo changes will be done at a discounted rate.
Change rpm limiter
Dyno tunes :
