car smokes, what could it be...
Old 06-04-2012, 05:10 PM
dans94z28's Avatar
Default car smokes, what could it be...
so the only time my car will smoke is when im decelerating and slowing down. its not all the time but after running it hard. the car is high mileage and doesnt smoke on acceleration or idling. only after i come to a stop then it puffs for a second and clears up. 170K miles, 50psi oil pressure. original heads and valve seals. pcv valve is new also.
Old 06-04-2012, 05:13 PM
JUSTINSWS6's Avatar
Valve seals
Old 06-04-2012, 05:54 PM
dans94z28's Avatar
thats what im leaning towards but wanted some thoughts before jumping into this. might try to make it a cam, lifter and head swap while doing it. I have a set of 853s and from what i gather they flow the same as the 241s that are on my car now. the difference being how they were cast or molded.
Old 06-04-2012, 05:57 PM
JUSTINSWS6's Avatar
They dont flow as good but are close. Dont do a heads cam swap on 170k motor get it rebuilt first.
Old 06-04-2012, 05:59 PM
Gunslinger09's Avatar
Any oil consumption between changes? It could indeed be the valve seals, it could also be some blow by from the rings if it's a real high mileage engine like you say. Try new valve seals first and see if that does it for you. If it doesn't it may be your rings and you might have to start thinking about a rebuild.
Old 06-04-2012, 06:02 PM
dans94z28's Avatar
well let me ask this, is a lq9 worth the swap? the extra hp vs extra 100lbs
Old 06-04-2012, 06:07 PM
JUSTINSWS6's Avatar
I dont think so. A lowmile used ls1 would be best
Old 06-04-2012, 06:58 PM
dans94z28's Avatar
i really dont think there is much blow by w the rings. I would have smoke under acceleration if so. or I would think.
Old 06-04-2012, 07:08 PM
dans94z28's Avatar
what if it was a lq9 w ls3/l92 heads? worth it then? these heads new are $360 with std valves, no hallow stem etc.
Old 06-04-2012, 07:29 PM
JUSTINSWS6's Avatar
Get a jnkyard ls motor and build it.
