Knocking? Not a pushrod..
Old 06-04-2012, 08:07 PM
wecruisin's Avatar
Default Knocking? Not a pushrod..
[youtube]0HJ52wC4ufk[/youtube]
[youtube]ZITtLxmBAOY[/youtube]
I've already pulled the pushrods and all were straight and its getting oil up top like it should.. What should I check next?
Thanks!
Old 06-05-2012, 05:05 AM
vettenuts's Avatar
Not sure of your setup, but if stock rockers make sure there are no bearing losses in the rocker trunnion.
Old 06-05-2012, 11:09 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I can't listen to videos....what lifters are you using and how much preload did you set them up with? Did this noise start after a modification to the valvetrain (new cam, etc)?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-05-2012, 03:11 PM
wecruisin's Avatar
All stock setup. 160k miles. Drove it to town and it did fine. Drove it back and it started ticking. Had oil and then I changed the oil just to see if it would make a difference and it didn't. Oil has been Mob1 Syn 5-20 with Mob1 filter since I got the car 2 years ago.
Old 06-05-2012, 03:21 PM
Gunslinger09's Avatar
When you changed the oil and there were no needle bearings from the lifters and the pushrods were all strait you need to look elsewhere. Check all your acsessory mounting points to make sure the hardware is tight. Make sure the tensioners are keeping the belt tight and check the belt to make sure it isn't boogered. Hows the oil pressure? That doesn't sound like the metal on metal clank of a rod knock but you never know it could be a bearing about to go.
Old 06-05-2012, 04:38 PM
99Bluz28's Avatar
Your oil pressure should be higher then that considering that the engine is still cold, has your oil pressure always been that low?
Old 06-05-2012, 04:43 PM
BarneyMobile's Avatar
I was thinking the same thing!
Old 06-05-2012, 05:33 PM
5w20's Avatar
why??
