Gonzo98
06-04-2012, 08:11 PM
Im looking to sell my 01' SS. I just got finished but a new job is taken my time elsewhere. It has 54,xxx miles on it and I just dropped in a LQ9 with a LS3 top end.
Engine
The block has 50k miles on it. The heads are ported with PRC EHT .675" springs. It has a TSP 231/236 .641''/.615'' LS3 cam. It has a stock LS3 intake with a edelbrock 90mm tb. The headers are TSP 17/8" ceramic coated headers with a bassani x pipe and spintech mufflers. It also has ls7 lifters and hardened pushrods. The oil pump is a new ls6 unit.
Trans/Rear
Built by Top Gear Motorsports in Mesa Az. Has a beast sun shell with all the goodies. The converter is a Edge unit and is a 4k stall. Trans has 500 miles on it since rebuild. The rear is the stock 10bolt with 3.73 gears.
Chassis/Suspension
Car has a UMI K member with tubular upper and lower control arms with adjustable QA1 coilovers and UMI solid motor mounts. The car also has UMI 3point sub frame connectors and a UMI tunnel mount torque arm. The Panhard bar is a adjustable UMI unit and the rear shocks are adjustable comp engineering.
Wheels/Tires
Wheels are Summit Drag thrust wheels with Mickey Thompson ET Street radials in 275/60/15 in the rear and 26/7/15 MT radial front runners.
Fuel
Racetronix pump with hotwire kit and stock ls1 injectors for now.
Im probly forgetting other stuff so feel free to ask. I owe a little bit of money on this car still so the title will come from the lender. Im asking 13,500 for the car and Im not looking for any trades.
http://inlinethumb54.webshots.com/51125/2256870530080028787S600x600Q85.jpg (http://sports.webshots.com/photo/2256870530080028787ShemFq)
http://inlinethumb01.webshots.com/50240/2773989750080028787S600x600Q85.jpg (http://sports.webshots.com/photo/2773989750080028787EHjnmW)
http://inlinethumb63.webshots.com/39998/2484862080080028787S600x600Q85.jpg (http://sports.webshots.com/photo/2484862080080028787zGsqCx)
http://inlinethumb10.webshots.com/48137/2240525450080028787S600x600Q85.jpg (http://sports.webshots.com/photo/2240525450080028787FKtKWa)
http://inlinethumb28.webshots.com/51291/2494918460080028787S600x600Q85.jpg (http://sports.webshots.com/photo/2494918460080028787oZVFLb)
http://inlinethumb16.webshots.com/50063/2189503330080028787S600x600Q85.jpg (http://sports.webshots.com/photo/2189503330080028787cHOgcM)
http://inlinethumb21.webshots.com/48212/2653714950080028787S600x600Q85.jpg (http://sports.webshots.com/photo/2653714950080028787EvnILZ)
http://inlinethumb15.webshots.com/49614/2269111330080028787S600x600Q85.jpg (http://sports.webshots.com/photo/2269111330080028787YXCbNH)
http://inlinethumb47.webshots.com/51438/2762565380080028787S600x600Q85.jpg (http://sports.webshots.com/photo/2762565380080028787rRlCea)
Engine
Trans/Rear
Chassis/Suspension
Wheels/Tires
Fuel
