Florida Members - sudden lose of power in 05 GTO
duvalsoldier904
06-04-2012, 11:12 PM
so it started the other day with the radio where i would be driving and the whole radio would shut off lights and everything but just the radio and today i was reversing out of a parking spot and lost power in the whole car i thought i stalled at first so i cranked it back up and drove home and then i stalled the car on purpose to see if the lights and stuff shut off with it and they dont need help with the sudden lose of power
marksceta
06-04-2012, 11:48 PM
Start off with checking the battery terminals, are they loose or corroded. Next test the battery and alternator. Check the connections at the alternator and fuse block under the hood. Hopefully you will find the problem or lead you in the right direction.
DYING BREED
06-05-2012, 12:09 AM
yup, check those and also where the main ecm is plugged in. those items loose or bad battery or bad alternator will wreak havoc on the running of your car, basically no correct voltage going to it at all times, computer cant run car correctly and parts cant do their job. let us know
wooddaniel
06-07-2012, 08:12 PM
Figure it out yet? Gto's are known to have gremlins, mine had some electrical problems and I had to get a new PCM eventually. Mine was an 06
duvalsoldier904
06-07-2012, 10:37 PM
No and its under warranty and the dealership has had it for 3 days now and they can't figure it out
wooddaniel
06-07-2012, 10:48 PM
That sucks man! Yeah mine had serious issues with going into limp mode, cutting off completely, ETC. Finally swapped a new PCM into it and it was fine after that. Not saying that's your issue, but if you could get em to replace it it might be. Does the car have extensive work done to it?
duvalsoldier904
06-07-2012, 11:12 PM
here is a list of mods it has its not much
http://ls1tech.com/forums/florida-members/1518801-just-bought-2005-gto.html
wooddaniel
06-07-2012, 11:59 PM
Strange that they can't figure it out. Mine did it with only 8K miles on it
Ls2SilverBullet
06-08-2012, 12:36 AM
Sounds like its shorting out. Check the wire from the battery to starter and make sure its not burnt from touching your headers
duvalsoldier904
06-08-2012, 07:39 AM
Ok so they couldn't find the short and they gave up on looking for it and told me to come pick up the car
DYING BREED
06-08-2012, 11:35 AM
unfortunately just cause its the dealer, doesnt mean they know how to fix it. Might have to make some calls to nearby performance shops maily dealing with GM's or even email.
duvalsoldier904
06-21-2012, 09:21 AM
Ok so they had the car for a little over a week and they can't figure out what was wrong but its not losing power now so they think it was a ground wire and when they were going through the car they fixed it... so the good part is they paid for the rental and I never had to pay for the work either
1badSS
06-21-2012, 10:18 AM
You can't beat that, hopefully it took care of the problem.
ramairetransam
06-21-2012, 10:40 AM
keep us updated
