General Maintenance & Repairs - 3.4l v6 Heater core hose, leaking..HELP.!
PURPLE PHANTOM
06-05-2012, 03:12 PM
okay, so i bought another firebird, its the 3.4l v6, its got a nasty antifreeze leak in the engine bay, from the heater core hoses (theyre all swollen) ive called junkyards, and tried ebay looking for a new set, and no such luck...not even the dealerships...soooo what can i do.? can i run just regular hosing through there, or do i need to try and bypass it.? i need help, please.!
Thanks in advance, Jonni O
BlackLS1Bird
06-06-2012, 09:55 PM
If it is just the hoses going from the engine to the firewall, just go to home depot, lowes, or other hardware center and get some heater hose like you would use on a household hot water heater in the same diameter as the hoses on your car and some hose clamps. It has to be the redish colored heater hose that is rated for high temp. Just cut to length and clamp it on in the stock locations.
