Blue_00_WS6
06-05-2012, 09:15 PM
Well. As stated. It is a 96 camaro with an ls1 swap. Hydrolocked the 1st ls1 motor and cracked the block. This was the first attempt to turn the motor over.
Fast forward to a new block and now find out, An injector is stuck on. Just 1. It is the front passenger side. Swapped injectors and same problem. Same one leaks, Front passenger. Swapped electrical connections and the leaking injector now followed the electric connection... This is only when the key is turned on or cranking.
Wasn't sure if maybe was a short, So I cut the wire just off the computer and jumped a new wire to the injector.. Same problem. The constant power to the injector is being ground through the computer all the time. I checked continuity. And the blk/grn wire has perfect continuity to a ground. But no other injector has that.
Thought maybe it was a bad computer, so swapped that out for another....and same damn problem. Injector remains open.
any help/suggestions are appreciated!!! Thanks
