Pontiac GTO 2004-2006 - Pulling out 06 GTO motor & engine harness?
silvertl
06-05-2012, 11:37 PM
Hey guys. I just recently picked up a 2006 GTO for a pretty good deal, but the engine needs to be pulled. Threw rod. It is a 6spd transmission. Would it be easier to take the engine harness off the engine first? or Unplug the Harness from the ECM and just pull the motor with harness attached? Secondly you you recommend pulling the motor from top or underneath?
I've tried searching to look for GTO builds with pictures to get an idea on different forums, but really couldn't find any. I want information from those who have actually pull a GTO motor, not just opinions.
Thanks guys.
Robofuzz
06-06-2012, 12:27 AM
Definitely pull the motor through the top.
gconnoyer
06-06-2012, 08:09 AM
Definitely through the top.
As far as the harness goes, not hard either way.
Id say unhook it from the motor so its not in the way once you start the teardown.
And will be in all the proper places when you get it back in
mark21742
06-06-2012, 08:31 AM
Unhook the wiring, then pull it out through the top. It's a pretty easy pull and I've had my engine out in less than two hours start to finish with the motor on the stand.
Don't know about the newer ones, but just to warn you on my 04 there is no drain plug for the coolsnt, just have to pull the hoses and sin the flow towards a pan lol
silvertl
06-06-2012, 09:07 AM
Thanks for the replies guys, i really appreciate it! I'm hoping to have it pulled this weekend to see the damage. I'm just going to try to leave the harness on the motor and pull it. obviously unhooking the necessary items to free the engine to be pulled lol
6PntHo
06-06-2012, 12:30 PM
I left the harness in the car, just unhooked it and pulled through the top
silvertl
06-06-2012, 09:40 PM
Yeah, i actually started pulling the radiator/power steering stuff. almost have the harness unhooked from the motor. Man is it a little bit of a pain. I'm use to imports :nono:
6PntHo
06-06-2012, 11:28 PM
just take your time, dont wanna really mess something up.
04gto5.7
06-07-2012, 12:28 AM
i would leave the harness in the car and just pull what is nessary off so that way its alot easier to put back in and have the plugs in the exact location but thats me ive done both
silvertl
06-07-2012, 01:56 PM
I have all the front sensors, as in the alt., temp sensor, all coil packs, injectors, ECM, etc pulled. The starter looks like it will be a bit difficult to unbolt the wires:bang:. But yeah definitely taking my time. Thanks guys
gconnoyer
06-07-2012, 07:47 PM
^^^this
