Generation IV External Engine - 24x or 58x relutor?
6togo
06-06-2012, 07:24 AM
I am putting together a LSX 427 and plan on using DBW which wheel do i need and i dont have the management system yet starting from scratch i may do a GM pcm or aftermarket depending on how my budget looks at the time? I cant seem to find the solid answer searching but most say a 58X but that could that be they have that system?
Sales2@Texas-speed
06-06-2012, 09:15 AM
There were vehicles with DBW throttle bodies that had 24X as well as a lot that have 58X, so from a PCM/management standpoint, you could do either. Aside from parts availability if you're looking at used, salvage, or other second hand parts I have not seen any empirical data that shows one is any "better" than the other.
Gray86hatch
06-06-2012, 03:28 PM
I would go 58x the reluctor is a better piece. Will handle the rpm better than a 24x
Tim
6togo
06-06-2012, 08:35 PM
So either will work but i would have more of a chance to find parts for the 58X is that right? More than likely i will be running a fast or big stuff system when funds permit!
Sales2@Texas-speed
06-07-2012, 10:30 AM
Tim
Better piece I could almost agree with, being it is a single wheel with no need to have them welded together to ensure they do not split. Handle RPM's better, I could argue either way.
Sales2@Texas-speed
06-07-2012, 10:31 AM
Yes and no...the 24X stuff was made for about 10 years, whereas the 58x stuff has only been around for about 5 or so. But, a lot of the 24X stuff ahs been wrecked, destroyed, etc. The 58X stuff on average is likely in a bit better condition.
6togo
06-07-2012, 02:26 PM
Sounds good thanks for the input now I just need to get the dragonslayer crank which I been told is not available until the end of July!
ws602
06-07-2012, 03:39 PM
late model engines have a billet 24 tooth wheel that they can put on your crank for you .Call them and Brian can explain the process i just had them put one on my crank.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
