camar0corey
06-06-2012, 08:43 AM
I'm not sure what is causing it. As you climb higher than 3k rpms the car becomes shaky, you can see the shifter stick vibrating. I might try to get some film of this later today. it seems to smooth out above 5k, but honestly lately I don't really beat on the car because this issue is freaking me out.
It is a LT1, I'm running the dual disc Mcleod in it with the steel flywheel. T56 I purchased used about 3 summers ago was supposedly rebuilt to level 2 specs by this shop owner in Tampa, yeah I know, kind of big gamble there.... Driveshaft is a Denny's Nitrous Ready. 12 bolt Moser rear with Eaton posi and 4.11 gears.
I notice I get a fairly nasty vibration on deceleration also if I let the car coast. Under load or braking I do not notice this other vibration.
Any ideas?
Edit: Just thought about this, it is especially noticeable in 3rd and 4th gear, it is still there in 5th, don't know about 6th. I haven't exactly been doing any high speed runs with the thing with the way it is behaving.:lol: I think the issue is there in 1st and 2nd but it isn't as noticeable, due to the gearing maybe?
Any ideas?
