New LS1 Owners - Newbie Tech - Bank 2 system reading lean
Jake18
06-06-2012, 09:17 AM
Just installed longtubes and ory on my car and I'm now getting that the bank 2 system is reading lean and the o2 heater is throwing a code. I deleted the air system before and when I got that tuned out I also got the rear o2's tuned out so I didn't think that was the cause of the engine light. Anybody know where to start with the bank 2 system running too lean?
BigBirdLS1
06-06-2012, 09:51 AM
How do you know that it is running lean. Are you using a wideband or got the DTC for it. Either way I'm sure it's just your sensor screwing up. Either the wiring for it or the sensor itself. Either way switch it out and problem should go away.
Jake18
06-06-2012, 09:59 AM
I don't have a wideband, thats what the OBD tool is saying the light is for.
BlackScreaminMachine
06-06-2012, 10:29 AM
Clear the code via the scanner and go drive, see if the code resets. Best you can do.
BadxLS1
06-06-2012, 12:53 PM
Had the exact same problem, put the car on our lift and swapped out the sensors and the problem moved to the other side, just bought a new sensor cleared the codes and it runs fine.
Jake18
06-06-2012, 10:54 PM
ive cleared the code twice and they came back up. guess im just gonna switch out both 02 sensors.
BadxLS1
06-06-2012, 11:28 PM
Before you buy new 02 sensors be sure you swap the bad one out with the good to be sure that's your problem, you don't want to go wasting money on something that you don't need.
Jake18
06-07-2012, 08:33 AM
the only problem there is i had to extend the drivers side because of the longtubes. the passenger side is still stock length.
Jake18
06-24-2012, 08:46 AM
brand new o2's, brand new exension wires... still throwing the same codes.. anyone know what to try next?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
