Scanner won't read my codes...
Took my car to autozone earlier this afternoon to get my codes scanned... but oddly enough their reader wouldn't pull up anything for my car... the screen just stayed blank.
They tested it on three other cars and the menu came up fine on everyone but mine..
This seems to be a major problem if I can't even pull the codes from the PCM... any ideas anyone?
Car is a 2000 SS.
Car is a 2000 SS.
Originally Posted by aNuBiS
maybe cause it hasnt set off any codes....
if the car is fine, you wont have any codes.
I reset the PCM to reset the SES light.. it came back on right away. I know I have some for sure codes.. being EGR... AIR... and rear 02 sensors.
The point was.. the scanner wouldn't even access the main menu when plugged into my car. Yet on cars that weren't throwing any codes and such it would come right up.
Originally Posted by slow
does your ciggarette lighter work?
the OBD-2 port, and the ciggarette lighter share a fuse, and if the scanner woudl not power up, its very common for the ciggarette lighter to blow the fuse, and the scanner won't have any power.
Ryan
Ryan
LOL, Figured as much.. dad was in my car trying to use the cigarette lighter and it just didn't work.. explains everything.. thanks.
