Dyno Guesses & Bench Racing Forum - Torquer V3 and 243's.....is this about right?
streetknight2
06-06-2012, 10:04 AM
Ok everyone, car is 02' Z28
Stock bottom end, 243's, Torquer V3 cam, LS6 intake, LT's, 3" ORY, LM1 exhaust, A4 with 3200 PTC stall, and 9" with 3.70 gears.
I took it to have it tuned a while back and it made 370/350. It had about a 6" spot in the exhaust they had down to a 2 1/4" pipe to clear the tunnel brace and it had a way wrong converter in it.
Car drives a ton better. Do the #'s sound about right or should I shop for a new tuner?
Gabbiani
06-06-2012, 11:29 AM
I've tuned several V3s - only one was an auto. Pretty similar to yours. Was 241 heads with a fast - 3200 stall - stock 10 bolt. Made 375 to the tire. Not to far off for cam only (mostly) on a stalled auto.
Was the converter locked. And do you have the graph?
thunderstruck507
06-06-2012, 11:34 AM
Do you still have the crap exhaust on it?
After seeing what dual 2.25" exhaust can do to a cammed ls1, a single 2.25" even a couple inches long will kill your flow.
Stock 243s?
streetknight2
06-06-2012, 11:42 AM
Don't have the graph and don't know if the converter was locked. When it was tuned before it had some trans issues which turned out to be a bad TPS causing some crazy shifts. It also had a Yank PY3600 stall in it which was causing it to drop from 6200 to 4000 on the shifts since it was so tight. The tuner suggested I change converters and bring it back for him to get the shift points set right but the engine tune would be ok.
I did replace the crappy exhaust with a 3" Pace setter ORY. I think it needs to be retuned as it doesn't shift gears until 3K RPM's on every shift. PTC also told me not to go WOT with the new converter until I had it tuned since I didn't know if the current tune had the TCC lockup turned off at WOT.
yelo04goat
06-06-2012, 12:01 PM
right on par with what my GTO made.
made 383/367 with a v3 ported 243s long tubes 3600 stall and crap 2.25 dual stock exhaust
lsxTAlemy
06-07-2012, 10:00 AM
seen 393 not sure on tq on m6 car
streetknight2
06-07-2012, 10:04 AM
I'm at vengeance racing right now. I'll let you know how it goes.
streetknight2
06-07-2012, 08:40 PM
OK everyone. Vengeance Racing got the car running better. He told me it wouldn't be a dyno queen and that's fine. The car drove like crap before I took it today. It's like a different car. I'm very happy so far. He even got a couple more ponies out of it.
It made 393HP/360TQ with the converter unlocked through the 3200 stall and 9" Ford rear, so I'm happy with what I've got. We'll get the #'s that matter next week at the track.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
