LS4 Performance - ls4 question
06GPGXP33
06-06-2012, 11:08 PM
i was curious what all was needed for a turbo to run on an ls4...(besides trans) like parts that make a turbo work. and do you need to do some motor work or anything? sorry for the stupid question, just curious
thanks guys
LS1 Racing
06-07-2012, 01:06 AM
Rather than answer the question directly, I suggest you look into one of the two available off-the-shelf kits. It winds up costing less than cobbling something together yourself, and it's designed for the car.
If you keep the boost down and/or use an intercooler, no engine upgrades are needed.
Brian396
06-07-2012, 08:09 AM
Why would you need a trans?
lVloses
06-07-2012, 09:29 AM
Trans is rated at 285hp and the LS4 puts out 303hp stock. Throw in the cartuning turbo kit and you're at 600hp roughly on a transmission rated at 285hp. That's why you need a beefed up transmission.
99slpws6
06-07-2012, 10:18 AM
Their are a few members on here with turbo kits and stock tranny, davidgxp had a fully built motor and had 50 plus track passes with the stock tranny.
The_Madcat
06-07-2012, 11:19 AM
He would be an exception to the rule. It's more than common knowledge these transmissions are pure excrement.
LS1 Racing
06-07-2012, 11:24 AM
I'm pretty Brian was just messing around, as he's enjoyed the same trans problems that most of have.
And DavidGXP rebuilt his tranny quite a while ago, as I recall.
Anyone doing a major build on one of these cars and is not doing a tranny has to expect that they will need one eventually.
DavidGXP
06-07-2012, 12:47 PM
I had my trans upgraded back in October. A valve in the channel plate came lose and caused a little shuttering. Nothing broke though:angel:
I think the trans is pretty tough. It's the valves in the valve body, and lack of trans cooler that burns these suckers up IMO.
Unfourtunatly, these cars are not being built anymore and are racking up miles, so planing for a rebuild is a good idea.
I did put over 50 drag passes on my stock trans (shifting at 6800 rpm) with plenty of 2.0-1.8 60ft times. It held up fine running 12's
I have not raced my new engine or trans yet though:(
Brian396
06-07-2012, 04:53 PM
Well crap I sidetracked this thread. My sig lists the Cartuning turbo kit and stock trans, so yeah I was trying to make a funny.
Ok back on track. The Cartuning kit is bolt on. If you've never messed with turbos that would be your best bet.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
