General Maintenance & Repairs - Passenger side turn signal/DRL not working, but parking lights work?
FSUNole17
06-07-2012, 08:53 AM
I have done a search on the board about this and am a little confused. Basically It sounds like it is either something to do with the DRL module behind the radio or flasher/blinkers under the dash. When I turn my parking/headlights on, both amber bulbs light up just fine. When the car is running with the e-brake off, I only have the driver's side DRL on, the passenger one is off. When I try to use my blinkers, the driver's side one works just fine, but the passenger side lights up the green arrow on the dash and just stays lit. I changed the bulb on Saturday so I know it is not the bulb and because it lights up when I turn the parking lights on, it can't be the socket. Does this sound more like a flasher issue under the dash or the DRL module behind the radio? I would like to not have to spend a ton of money on a module for something that isn't even required by law but would like the functionality of my blinker back. Thanks for any help
betterbait
06-07-2012, 10:30 AM
Im having the same issue with my 96. left blinker wont work but right does. All bulbs replaced.
juSStin4171
06-07-2012, 10:33 AM
I have the same problem on the C6... passenger side too :suspicious:
The blinker on the dash and the rear turn signal flash about twice as fast... when the headlights are on it lights up tho... WTF?!
wssix99
06-08-2012, 09:07 AM
What happenes when you use your hazards? That will tell you wherre the problem is.
FSUNole17
06-08-2012, 11:09 AM
Hazards - the passenger side amber light does not light up. So either BOTH my flasher/blinker things under the dash are bad or it is the module, which sounds more like the module, right?
wssix99
06-08-2012, 12:57 PM
Yes, indeed.
FSUNole17
06-08-2012, 02:47 PM
Is there any way to get the blinker to work without buying a module, like a ghetto rigging that can get me by?
wssix99
06-08-2012, 09:40 PM
The problem is a bad relay in the module. Theoretically... you should be able to crack the module and just replace the relay. (If you can find the part.)
BLK LSWON
06-08-2012, 09:48 PM
My drivers side DRL does not work when in the day but at night with my lights on it somehow works...??
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
