98formulata
06-07-2012, 10:32 AM
2000 z28 camaro
145k on the body
only 47 miles on the 6.0
05 model lq4 fresh from the machine shop
new cam, rod, and main bearings
plasma rings
arp rod bolts and head studs
gm mls head gaskets
ported oil pump from vengeance
vrx3 cam, hardened push rods and 660 lift springs
ls6 intake and ported factory tb
2 bar map
speed density tune
underdrive pulley
400 trans, mildly built. full manual transgo kit
i was told when i had it built it was good to 700
quicksilver shifter
driveshaft has a vibration at about 60, which im sure is the pinion angle
bmr torque arm
bmr lca's
strange shocks
twin 255 fuel pumps
boost referenced fuel pressure regulator
return style fuel system
60lb injectors
1 3/4 headers
pacesetter y pipe with a bullet
ac is not on the car but i am in the process of putting it on
interior is all black. leather.
no rips or tears
has a scratch on the drivers side qaurter panel
asking 6500 obo
call or text me at 615 525 1837
not interested in trades
145k on the body
plasma rings
gm mls head gaskets
2 bar map
speed density tune
underdrive pulley
quicksilver shifter
bmr torque arm
bmr lca's
strange shocks
twin 255 fuel pumps
60lb injectors
1 3/4 headers
no rips or tears
asking 6500 obo
