Drag Racing Tech - What should i expect 60 ft?
View Full Version : What should i expect 60 ft?
+badss+
06-07-2012, 12:12 PM
Hey guys what should I expect for a 60 ft. Here's my specs
02 Camaro ss
Aes forged 390 9.5-1 cr
F1A pro charger 15psi should be around 800rwhp range
Jakes performance 4l80e fmvb with t brake and billet 3600 stall
Strange 3in. Chromoly drive shaft
Strange S60 with s trac 3.73 gears
Bmr adj. TA and lca
Car weighs around 3800 with driver
I'm using afco 3870r with stock spring in rear
No front sway bar
Stock springs and bilstein shocks
Bmr turbo k and lca with race star 15 drag set up using
Hoosier 17317 DR's if you need more info let me know
Just trying to see where I should be at. Thanks
Longbob
06-07-2012, 02:08 PM
Just a wild guess, but I would say 1.48. I think the rear gear, weight, and converter will hurt you.
+badss+
06-07-2012, 02:34 PM
To much gear? Weight is that for now and is stall to much? I also am using msd 2 step
+badss+
06-07-2012, 02:36 PM
But a 1.4x is still moving out.
BrianSF-GA
06-07-2012, 02:45 PM
Work on trying to hook it before you worry about what your 60's should be. That is a whole lot of power to get down! Are your AFCO's DA or SA? I am in the process of installing my Strange DA fronts ... once I come off the line without spinning THAT is where my 60 "should" be.
Nevertheless, you should run some pretty good ET's with that power though a braked 4l80!
With all that said .... first time out .... 1.55's and working toward 1.45's.
+badss+
06-07-2012, 03:25 PM
DA, when I can I'm also going with there DA coilover in front. Going to try and get the car down to 35-3600 when I get the parts together for it. Just trying to gauge what I should be able to get out of my set up for now. I'm sure I'm asking alot of the DR's I have but hey a little patience and who knows.
+badss+
06-07-2012, 03:27 PM
thanks for the imput guys so 1.5x - 1.4x til i can get the fronts done and pray for traction.
+badss+
06-07-2012, 03:31 PM
I figured with alot of power adjustability would be key to try and get a 275 to hold. I am really just trying to see if i can make a 275 work, since it is a lighter tire before i jump to a 325. I don't have to bfh and fender roll the car.
Longbob
06-07-2012, 04:45 PM
Not enough gear. I think a 4.33 or 4.56 would be closer.
Without seeing your dyno sheet, it still appears that a 3,600 stall is too low. I would think closer to 4,200, but the dyno sheet would help.
I don't know what you plan on leaving with on the 2 step, but the lowest I can go is 3,000 and that would be way to close to your converter stall. I don't think you could hold your car on the line.
I have 4.88 gears, weigh 3,300 with the driver, 5,600 stall, dual Mark Williams calipers on the rear, and it is like a caged tiger when I leave at 4,000 on the 2 step. I can hold it to 4,200 and that is it.
My best 60's are in the 1.29 range and I go through the lights at about 7,500. This is with a N/A stock eliminator motor that makes around 522 hp.
Longbob
06-07-2012, 04:48 PM
If it were me, I would take that bad boy out and make a couple of passes. You might be surprised at what is working and what isn't. I know I get surprises all the time.
See what kind of times it runs and where you are having problems. I bet we can get it resolved pretty quickly.
Longbob
06-07-2012, 04:52 PM
I didn't see the transbrake and now I do. You will put a lot of pressure on that transmission with too high a 2 step and that low a converter flash.
+badss+
06-07-2012, 05:08 PM
Well I'm only spinning motor to 6600 rpm. I think higher stalls work for n/a but lower is better for boost since power will be on the big end. The stall is what has been recommend. Figure I'm gunna try around 3k launch still not sure how tires will like it, the guys at Lashway are going to help with setting the suspension up. Car will be ready by the end of the month.
BrianSF-GA
06-07-2012, 06:07 PM
I wouldn't go with any more gear than a 4.30 and even that wouldn't give you much room to grow ... you will run out of gear at 128 mph.
As I and others have said, get it out there and see where it is before you go changing too much and make changes one at a time to see what works and keep track of the results. I dropped to a 1.66 60' and still spinning more than I want. Once I get my front DA's on and the front sway off, I will get serious with my E/C settings front and rear. When I am back out, I will also have fresh plugs, wires and fuel filter to be sure it is at its best.
Subscribed .... keep us informed.
