Drag Racing Tech - pickup 3-4 tenths
View Full Version : pickup 3-4 tenths
232 racing
06-07-2012, 08:51 PM
01 ss camaro tsunami cam 799 heads ls6 intake long tubes HP tune slp lid and maf good exhaust m/t et drags tring to pickup 3-4 tenths any ideas
Nemesis350
06-07-2012, 09:25 PM
sorry, but you're giving no one here anything to actually work with. auto? manual? times? traps? 60 ft? maybe even some info on your tune??
heymoej
06-07-2012, 09:27 PM
sticky tire & about 350#s of weight reduction.........
232 racing
06-07-2012, 09:33 PM
Auto 3700 stall 1.8 /60' 8.0 1/8 85 mph
nocooler
06-07-2012, 10:54 PM
Start with the 60' - 1.8 blows.
bufmatmuslepants
06-08-2012, 09:06 AM
Im gonna go with suspension; LCAs and TA with TA relo mount would be a good starting point, as well as strip 300lbs off of it.
thunderstruck507
06-08-2012, 09:36 AM
If you're trapping 85mph with a Tsunami cam and 799 heads, your car is royally fucked somewhere. You are missing at least 5-7mph MINIMUM.
I have a smaller cam in heavier car with less aero and it traps 91-92mph and runs 7.5s
Fix your car and you will gain more than 3-4 tenths. If you want help, you're going to have to start posting from a computer instead of a phone and give a lot of details. One sentence posts with no punctuation are going to drive away anyone intelligent enough to help you.
Start with basics:
running premium fuel?
no codes?
fuel filter clogged?
good fuel pressure?
compression check on engine
transmission slipping?
weight of the car with you in it?
tuned by someone who knows what they're doing?
what density altitude are you racing in (elevation with weather factored in)?
01ssreda4
06-09-2012, 01:36 AM
^^^yep, good answer.
Leeroyws6
06-09-2012, 07:31 AM
what gears?
