Swap 2004 gto into 66 lemans
Have a 66 lemans I will be doing complete frame off resto I just picked up a complete 2004 GTO wrecked front end not that much damage actually drove it on my trailer got it for a steal $4200 complete car with 6 speed T56. I plan on transplanting the ls1 and tranny, using the interior what what else can I use and can I use the entire wiring harness if so what wires can I delete and who do I have flash PCM. thanks
Ditto, start with the stickies, lots of good stuff here. The engine and body wiring are for the most part isolated from each other. You will most likely find that running the engine systems off the PCM and running the OE 66 body harness will work the best. That is what most of the guys here seem to have done.
Take your time!!!!!! Don't get in a hurry. The task looks monumental right now, but it really is not that hard if you plan well.
Ask lots of questions, you will get the right answers here.
