pea_jay
06-08-2012, 12:19 AM
Really like to trade for another m6 trans am.
Can text more pics 304-928-7736
331 stroker
pro comp aluninum heads ported with 202 valves
screw in studs and guide plates
double valve springs
harland sharp 1.7 rockers
ported and polished cobra upper and lower intakes
90mm mass air
65 mm tb
42# injectors
MSD ignition and boost controler
flowzilla fuel pump
vortech s trim supercharger
bbk equal lenth headers
3inch x pipe
3 inch race mufflers and full 3 inch tail pipes
E303 cam
t-5 with centerforce clutch and pressure plate
subframe connectors
UPR lift bars
Koni shocks
moroso springs
solid motor and transmission mounts
new 4;10 richmond gear
new ford motor company posi unit
new billet shifter with pistol grip
monster tach
boost gauges
battery in the back
new 225 60 15 on back weld wheels
paint is 6 months old
tru fiber 5 inch hood
heres a vid of it running
Radio and AC Delete
Close to 500whp
http://www.youtube.com/watch?v=OXm0JazSmbA&list=UUJvH1QA_DwZylkd8sFz-jFg&index=2&feature=plcp
http://www.youtube.com/watch?v=OXm0JazSmbA&feature=g-upl
331 stroker
90mm mass air
65 mm tb
42# injectors
flowzilla fuel pump
3inch x pipe
E303 cam
subframe connectors
UPR lift bars
Koni shocks
moroso springs
monster tach
boost gauges
battery in the back
Radio and AC Delete
Close to 500whp
