2001 PCM work with 1999 motor?
Watch out for the fuel injectors...'99-00 had 26# whereas '01 had 28#.
If the '01 PCM has stock configuration, you'll want to either have it reprogrammed or just swap in a set of '01-04 28# injectors.
It will probably run OK, but not the same. Even if you change to 28# injectors, it's programmed for the different cam of 2001+, which has overlap to compensate for no EGR. And there are a bunch of tables (like, knock sensor tables) that are different for no obvious reason.
LS1TECH & Trucks Sponsor
Incorrect. 58x didn't even exist during the years of F-body production.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Well I was gonna take a 2001 and have a tuner dyno tune my car for the 99 motor that I have...which I am guessing is very possible.
Just curious though... I am gonna guess on this one...none of you have ever done it?
You don't necessarily need tuning if you're using a factory '99 engine, just somebody with EFILive/HPTuner/LS1Edit and a '99 factory binary to strip out the right tables and paste into the '01 PCM config.
