Tools & Fabrication - Rusty Craftsman Set
axlrose
06-08-2012, 08:50 AM
I have one of those big craftsman ratchet/wrench sets that come in the plastic box.
For some reason everything got covered in rust on the inside(I got them from my dad). If I take them back to sears will they replace them?
If not, what is the best way to clean them? I've seen something about soaking them in ATF and Paint thinner, but I would prefer a new set :)
spaulding
06-08-2012, 10:05 AM
Dunno if theyll replace but soak um in a tub of clr overnite was with water and coat in wd40 and wipe dry
BAMALS1
06-08-2012, 02:37 PM
Try soaking aluminum foil in water and then and try to rub it out with it. I cleaned up a chrome mongoose bike once that had surface rust on it using this method...turned out great.
AlamoTA
06-08-2012, 03:02 PM
Depends on who you get. I used to work in the Sears too department. If they are just rusty, then they still work you just nelelcted them and they can be clean up. However, if you ask and they say no, just ask for a manager and start making a scene, management will cave almost everytime. It's the whole customer satisfaction thing. I'd try cleaning them like mentioned above. Sounds like just surface rust.
bigbadblack93z
06-14-2012, 04:07 PM
depends on how old they are. I'd rather have an old rusty craftsman set than the newer lesser quality stuff. the new stuff does seem to corrode pretty quickly though.
Try soaking it in WD40 or similar then wiping them down w/ a fine scotch brite.
G-Body
06-15-2012, 12:37 AM
I also would avoid trading them in, oil them down with a bit of wd40 and use as is. If you trade them in you will probably end up with at least some china made stuff which my have nicer chrome now, but it doesn`t seem to be as durable as the older craftsman stuff.
flintwrench69
06-30-2012, 04:21 PM
Back in 93 I had a tool box with a complete craftsman set in my car when it caught on fire. I asked the guy working at sears about it, he said yes even if they had been in a fire they would exchange them for new. Well when I brought the tools in, that guy wasnt working that day & they refused to do anything. I was so mad for 2 reasons: the employee that said I could bring them in & they said no, & everywhere in the tools section theres signs that say GUARANTEED FOREVER. When I asked them about this they couldnt give me an answer & got irrate, told me to leave or they were gonna call the cops. I made some phone calls, one was the sears tower so after a few days I was notified that I could bring my stuff in & they finally did give me new tools.
bwkmaro
06-30-2012, 10:43 PM
dont trade them in unless you want china made tools. i used craftsman for years but since the switched from usa to china quality went way down i now have a snapon set, back to problem free work days
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
