where can i find gauge needles?
while replacing the light behind my gas gauge i want to swap to a different color needle while i have the gauge cluster out. anyone know where i can pick some up?
damn i didnt realize it would run me that much. maybe i'll get some later down the road.
thanks guys
btw cajunfirehawk your overlay and white needles look nice, do you have a pic of it installed just for kicks?
thanks guys
LEDs are the easiest of everything to do. The bulbs are in sockets that twist in from the back. Remove bulb socket, remove old bulb, insert LED, twist socket back in place. Done. 2 sockets are for the turn signal indicators and 1 is for the high beam indicator. I just left those as standard bulbs.
Needles take a little bit of time to do. I didn't follow S86's directions completely as I found that when I would turn on the ignition (but not start the car) that a several of the needles would move to a particular location every time (I tested this several times before moving forward). The tach I did wait until it was totally warmed up to put that one in place, but since my car is cammed it is still only an estimate as at idle it bobs around a little bit I had to adjust the speedo needle a couple times, and I pushed the volts needle on too far and had to redo it.
Do yourself a favor and wear a latex glove when doing the needles, otherwise you'll get little shiny spots from the grease on your fingers all over your overlay. Not cool.
I have no experience with an overlay change so I have no input there.
Just because I want to show off my LEDs and needles a little bit I have white needles but at night they glow the backlight color. I love it.
my bad i missunderstood, thanks for clarifying
1 Post
If you don't have the money for them, you may be able to look into another cars needles. I know a guy not to long ago posted up where he took the needles out of another car and not a Camaro or T/A, I forget what kind of car they came out of but he worked with them and made them work and it actually looked pretty good.
