Generation IV Internal Engine - Which gasket for my Ls2?
View Full Version : Which gasket for my Ls2?
slo89lx
06-08-2012, 06:02 PM
So two different company told me two different gaskets to get for my stock ls2 with 317 heads to 9:5:1 compression, the is a turbo build project
The first guy said: Bore: 4.130 with a .060” thickness would yield an approximate compression ratio of 9.55:1. Bore: 4.130 and .070" thinkness will result in a slightly lower compression ratio of 9.36:1.
the second guy said It would require a .080 gasket which is really thick so we don't recommend it. , also, it would be custom
So which one would get me to my goal? thanks for your help
slo89lx
06-08-2012, 06:03 PM
P.s there flat top piston
Sales2@Texas-speed
06-11-2012, 09:49 AM
For a stock LS2 bottom-end and stock 72cc chamber 317 heads, you'd need about an .080" thick gasket to get down to 9.5:1 static compression. Personally, I'd rather run a bit higher compression with a reasonable quench rather than lower compression and a loose quench.
slo89lx
06-11-2012, 04:43 PM
Thanks for the help, im going to try the ls9 gasket out
Sales2@Texas-speed
06-11-2012, 04:46 PM
Anytime! We keep the LS9 gaskts in stock and can usually ship the same day they're ordered!
http://www.texas-speed.com/p-2129-gm-62l-multi-layer-steel-ls9-7layer-cylinder-head-gasket-sold-individually.aspx
