Fueling & Injection - Pump HAS power, Pump DOES work. Install it and it WONT WORK??
Darylofpv602
06-09-2012, 01:42 AM
Theres power to the fuel sending unit 4prong deal inside.
Theres power to the connector that plugs into the racetronix fuel pump
Plug it in, plug the ground on. Turn the key over... NOTHING
When pluged in, NO POWER OVER THE CONNECTOR
I know the fuel pump works. I took the not fuel pump end of the connector to wire a 9v to see if it'll turn. It worked.
..... EVEN MY OLD PUMP WORKS soo its not a RACETRONIX thing. This is FUGGING dumb.
Anyone think they know the answer?
1998 LS1 Camaro
Darylofpv602
06-09-2012, 03:06 AM
Lonnies Performance
06-09-2012, 09:34 AM
Just because you can measure voltage with a multimeter, does not mean it has enough current capacity to support the electrical load of the pump.
Try measuring the voltage with the pump connected... it may read near zero.
A bad connection or wire that is nearly broken in half can cause this type of problem.
Check/clean you connections & try again.
Darylofpv602
06-09-2012, 05:40 PM
Will do. That does sound probable. I'll Check it out, maybe even check stuff from the PCM, Fusebox, and ontop of the fuel sending unit. Ill probobly post again in 6 hours. :bang:
Thule
06-09-2012, 07:34 PM
if let the pump turn dry out of the tank you could have run it, both walbros and the oem's cant stand running dry,
Darylofpv602
06-10-2012, 01:50 AM
So i ordered a wire kit from
http://www.racetronix.biz/itemdesc.asp?ic=FPWH%2D002&eq=&Tp=. Lets see how it does.
Darylofpv602
06-12-2012, 07:45 PM
Got the wirekit - Thankfully I ordered it early. It WAS a bad few wires. there were cracks and a bit of corrosion on a few places on the positive side of things, grounds looked crappy too. Ill be installing the wirekit here when the sun goes down.
