Generation IV External Engine - What kind of numbers do you think?
jenkns7
06-09-2012, 08:40 AM
What kind of numbers do you guys think my car will be making once my set up is done...working on it now should be done in a couple weeks...2002 camaro ss...slp air box,pacesetter long tubes,ls6 intake,gmmg no cats exhaust,prc 215 heads,new era street sweeper ht (comp cam) .612 lift,42 lb green top injectors,ls2 timing chain, ls7 clutch,stock gears,stock rear end
1999FirehawkLS1
06-11-2012, 04:25 PM
Specs on cam? and ur in the Gen IV section if its a LS1 bottom end u'll get better results posting in the Gen III section
