WS.SIX
06-09-2012, 01:16 PM
Spirited driving on an hour long road trip, on the way back the service engine soon light began to flash. Code p0308: Cylinder 8 misfire. (Didn't know which cyl until I was able to get home, if i kept revs at 1500 or below it didn't seem to misfire enough to trigger a CEL or at all maybe)
So I pull over, since it was throwing a misfire all visible wiring, spark plug wires (except for 8 I couldn't reach it from the top) all I could see seemed fine. Checked engine oil, level is fine, checked trans fluid, level is fine, checked flexplate bolts, they are perfect. I'm sure the engine would have been shaking but I have solid motor mounts so she wasn't budging.
I get home and hook it up to the scanner (I have a tech force 2) and read the codes and datastream information from the vehicle. p0308 and there has been a lot of misfire count (over 5600) in the history on cylinder 8.
I jack up the car and access the #8 plug wire from the bottom... loose. I snug it back on there sit her back down and try to snug the top of the wire by the coil. I notice a little bit of oil around the area. I glance to the right and I see the PCV nipple coming off the valve cover is not connected. The hose came off and is laying beside it. I reconnect that and fire her up.
All seems well, no crazy sounds and the engine is running normally. I connect the Tech Force 2 scanner back up and go for a drive. Misfired once in about 10 minutes. Everything felt strong so I took it to redline... running perfect. I get back to the house thinking I may have dodged a catastrophic failure and then as its sitting there idling for a minute... I hear what sounds like something tapping in a single cylinder. Key off, time to go to work... called a cab.
The tapping at idle (seems to go away if at anything over idle) seems to change in intensity. it will be quieter, then louder, then quieter... a single hit each time. The question is... what is hitting where? :huh:
2000 T/A stock longblock, stalled A4, 116k
