General Maintenance & Repairs - AC line torque specs???
rollinna65
06-09-2012, 02:52 PM
Anyone know the torque specs for the AC lines on a 2000 Z28? I have them down to 19 lb ft but one is still leaking a little.
LS1121
06-09-2012, 03:19 PM
The book for my 98 says 24 ft. lbs. I would think it to be the same for you.
great421
06-09-2012, 06:14 PM
It's a German-based torque setting:
"Goodentight".
Seriously, my 96 service manual has a range; different torques for different liines, from 13 ft/lbs to 62 ft/lbs, so which line specifically?
rollinna65
06-09-2012, 09:54 PM
It's the line that runs from the condenser to the evaporator and it's leaking where it seals up to the evaporator. I've tried both the regular green o-rings and the metal/black rubber o-rings. No matter how much I torque them down they continue to leak and I don't want to go past "gutentight." So I'm guessing either the flange surfaces of the evaporator or the line are messed up, and the line is the easiest to replace, so that'll be the next thing that gets replaced.
great421
06-10-2012, 02:53 AM
FYI - My 96 Service Manual says 28 ft-lbs for that fitting.
rollinna65
06-10-2012, 11:23 AM
Awesome. Thanks for your help, guys.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
